Aluminum Q&A
June 2026
By: TONY ANDERSON
Q: I have been conducting welding procedure qualification tests in accordance with AWS D1.2, Structural Welding Code — Aluminum. I am welding 6061-T6 base metal with ER4043 filler metal. The problem I am experiencing is the failure of the guided bend tests. I am performing two root bends and two face bends, as required by the code. My two tension tests from the same test plate are passing the reduced section tension test.
A: The guided bend test has been a..
Already a member? Log In
D_Magnifying_Glass_Search.svg
Search Articles
D_PDF.svg
Publication Archive
D_Globe.svg
AWS News
