Jump to:
A Guide to Welding Automation: Cobots and Robotic Welding
Welding automation has moved past the experimental stage. What once lived almost exclusively on automotive assembly lines is now standard equipment in small and mid-sized fabrication shops, and the welders who understand how to work alongside it are the ones positioning themselves for the next stage of their careers. Discover what robotic welding automation actually involves, where cobots fit into the picture, and how AWS's live Introduction to Welding Robots and Cobots course can help you evaluate, operate, or manage an automated welding cell with confidence.
Why Welding Automation Is Now the Baseline, Not the Exception
Manufacturing is under pressure from three directions at once: a shrinking pool of experienced welders, tighter quality tolerances, and customers who expect faster turnaround without sacrificing consistency. Automation in welding has become the practical response to all three, and it is no longer reserved for mega-manufacturers running dedicated production lines. As AWS covered in Robots for the Rest of Us, collaborative robots and modular welding cells now let a five-person shop automate a single repetitive process without redesigning its entire floor.
That shift matters most for the people already in the trade. Automation is not replacing the manual welder. It is changing what "welding job" means, opening roles in robot programming, quality assurance, and system supervision for professionals who take the time to learn how these systems work. Traditional welders, inspectors, and shop managers who understand robotic welding automation now will have the clearest path to the higher-paying, less physically demanding roles automation creates.
Robots vs. Cobots: Knowing the Difference Before You Automate
Not all welding automation looks the same, and the terms get used loosely. A traditional industrial welding robot is typically fenced off, runs at high speed on a fixed, pre-programmed path, and is built for high-volume, repeatable production, such as long runs of an identical automotive bracket. A collaborative robot, or cobot, is designed to work in the same space as a human operator. It runs at reduced speed, uses force and torque sensing to stop or slow when it senses unexpected contact, and is typically faster and less expensive to reprogram for a new job.
That flexibility is why cobots have become the entry point for shops that run smaller batches or a high mix of part types rather than one product at high volume. A shop that switches jobs several times a week generally gets more practical value from a cobot cell than from a caged industrial robot built for a single, unchanging task.
The Structural Components Behind an Automated Welding Cell
Every welding robot or cobot system, regardless of size, is built from the same core structural components:
Manipulator (the arm): the multi-axis structure that moves the torch through the weld path
End effector: the welding torch or gun mounted at the end of the arm
Wire feeder and power source: deliver filler wire and welding current to the torch
Positioner or fixture: holds and often rotates the workpiece so the robot can reach every joint
Controller: the "brain" that stores the programmed weld path and parameters
Safety system: light curtains, safety mats, or force sensors, depending on whether the cell is a caged industrial robot or a collaborative cobot
Understanding how these pieces work together, rather than treating the robot as a black box, is the first practical skill AWS's course builds.
Programming Basics: What Learning to Run a Robot Actually Involves
One of the biggest misconceptions about robotic welding automation is that it requires a background in computer science or engineering. It does not, at least not at the introductory level. Most welding robots and cobots are programmed one of two ways: lead-through programming, where an operator physically guides the torch through the weld path and the controller records it, or teach-pendant programming, where an operator uses a handheld control panel to set waypoints, weld angles, and travel speed.
From there, the operator sets weld parameters, such as voltage, wire speed, and travel speed, largely the same variables a manual welder already controls, just entered into a controller instead of adjusted by hand in real time. Offline programming software exists for more advanced production environments, but a beginner-level course focuses on the foundational skills: understanding the weld path, setting parameters, and running test welds to verify quality before full production.
Weighing the Limitations Against the Productivity Gains
Automation is a genuine productivity tool, but it is not a fit for every job, and a credible course does not pretend otherwise. On the advantage side, robotic and cobot welding delivers higher production consistency, reduced cycle times, improved weld repeatability, and a safer environment for human operators, who step back from constant arc exposure and repetitive strain.
On the limitation side, automated welding cells generally need tighter part fit-up and fixturing tolerances than a skilled manual welder can compensate for on the fly. Setup and cell design carry real upfront cost and time. High-mix, low-volume, one-off, or field welding work, where a manual welder's adaptability is the advantage, is often not a strong automation candidate. Recognizing which jobs belong on a robot and which still belong with a manual welder is itself a skill, and it is one this course is built to teach.
How This Course Helps You Evaluate Whether Automation Is Right for Your Shop
For production managers, supervisors, and shop owners, the hardest part of automation is usually not the robot. It is the decision. AWS's Introduction to Welding Robots and Cobots course gives decision-makers a foundational framework for that evaluation: what a cell actually costs to set up and run, which jobs in a given shop are strong automation candidates, and how to measure return beyond raw arc time. As Robots for the Rest of Us notes, the real return on an automation investment shows up in reduced rework, improved throughput, better ergonomics, and more predictable scheduling, not just faster welds.
Certified Welding Inspectors and quality assurance personnel get a parallel benefit. Automated welding parameters directly affect weld integrity and consistency, and understanding how a robot's programmed path and settings translate into finished weld quality is increasingly part of the inspection conversation.
What to Expect from the Live, Instructor-Led Webinar Format
This is a live webinar, not a self-paced recorded class, and that distinction matters for how you learn. The course runs across four live sessions, held Tuesdays and Thursdays from 6 to 8 PM ET, with the next section scheduled for Oct. 20 to 29, 2026. Each two-hour session includes direct interaction with the instructor, meaning you can ask questions about your own shop's equipment or use case in real time rather than waiting on a support ticket or a discussion board reply.
The course is taught by Marvin Herrera, CWI, CWE, a welding engineer with more than a decade of experience in welding, manufacturing engineering, automation, and education. No programming or engineering background is required to enroll. A basic understanding of welding processes is helpful, and familiarity with industrial automation is a plus, but neither is a prerequisite.
Earning Credentials That Count: PDHs and CEUs
Completing the course earns 8 Professional Development Hours (PDHs) and 0.8 Continuing Education Units (CEUs). For welders, inspectors, and educators who track ongoing professional development, that is a tangible credential attached to real, applicable skill-building rather than a generic certificate of attendance. If you hold a certification with PDH or CEU requirements, confirm with AWS how this course applies toward your specific renewal before registering.
Who This Course Is Built For
Experienced welders and fabricators looking to move away from the physical demands of manual welding and toward higher-paying robotic operator or programmer roles
Production managers, supervisors, and shop owners evaluating whether and how to bring automation into their facility
Certified Welding Inspectors (CWIs) and quality assurance personnel who need to understand how automated parameters affect weld integrity and compliance
Technical educators and training coordinators modernizing a curriculum to match current industrial demand
Automation beginners with welding process knowledge but no prior robotics or programming experience who want a structured, credentialed entry point into the field
Advancement Opportunities for Robotic Welding Technicians and Operators
As welding automation becomes more common, opportunities are growing for technicians and operators who can work with automated welding systems and build on their existing welding knowledge. The Certified Robotic Arc Welder (CRAW) provides experienced welding personnel with a pathway to develop and demonstrate their skills as they move into robotic welding roles.
Supporting that career pathway is a growing framework of industry standards. AWS’s D16 Committee on Robotic and Automatic Welding has developed standards and guidance addressing robotic welding safety, system components, risk assessment, personnel qualification, and training. Together, these resources give manufacturers, employers, and welding personnel a foundation for implementing and supporting automated welding systems safely and effectively.
Frequently Asked Questions
What is the main difference between a traditional industrial welding robot and a collaborative robot (cobot)?
An industrial robot is typically caged, runs at high speed on a fixed path, and is built for high-volume, repeatable production. A cobot works alongside a human operator, runs at reduced speed with force sensing for safety, and is generally faster and less expensive to reprogram, making it a better fit for smaller batches or a higher mix of job types.
Do I need a background in computer programming or engineering to take this introductory course?
No. The course is built for beginners and covers programming at a foundational level, using lead-through and teach-pendant methods rather than code. A basic understanding of welding processes is helpful, but no prior robotics or programming experience is required.
Is prior manual welding experience mandatory to understand robotic welding concepts?
It is not mandatory, but it is helpful. AWS notes that a basic understanding of welding processes is beneficial for this course, since much of robotic welding automation involves translating skills a manual welder already has, such as reading a joint or judging weld quality, into programmed parameters.
How does implementing automated welding systems improve workplace safety for human operators?
Automation reduces the amount of time operators spend in direct arc exposure and repetitive, physically demanding positions. Collaborative robots add force and torque sensing that can stop or slow the system if it detects unexpected contact, and traditional industrial robots are typically isolated behind safety fencing or light curtains to keep operators clear of the working envelope.
What are some of the unexpected limitations or constraints when transitioning a shop to robotic welding?
Automated cells generally require tighter part fit-up and fixturing tolerances than a skilled manual welder can compensate for by eye. Setup, fixturing, and cell design carry real upfront cost and time, and high-mix, low-volume, one-off, or field welding work often is not a strong automation candidate. Identifying which jobs in your shop are actually a good fit for automation is one of the most valuable, and most commonly underestimated, parts of the evaluation process.
Register for AWS's Welding Robots and Cobots Course Today
Welding automation is not a distant trend. It is the standard your shop, your customers, and your career are already being measured against. AWS's Introduction to Welding Robots and Cobots course gives you a structured, instructor-led way to build that foundation, whether you are a welder eyeing a robotic operator role, a CWI evaluating automated weld quality, or a shop owner deciding if a cobot cell belongs on your floor.
The next live section runs Oct. 20 to 29, 2026, with seats limited to keep instructor interaction meaningful. Register for the course and earn 8 PDHs and 0.8 CEUs while building a skill set that is quickly becoming essential across the trade.
