Welder Qualification vs. Welder Certification: Clearing Up the Confusion
November 2026
Misconceptions about welder qualification and certification remain common throughout the welding industry. Although the terms are sometimes used interchangeably, some welding professionals insist that welders can be qualified but cannot be certified.
As a quality professional with nearly 40 years of experience and a Senior Certified Welding Inspector (SCWI) who has certified thousands of welders, I have encountered this disagreement repeatedly.
Definitions published by the American Welding Society (AWS), along with the requirements of applicable welding codes, provide a clear basis for understanding the relationship between qualification and certification.
The question is straightforward: Are welders qualified, certified, or both?
What do the AWS Definitions say?
AWS A3.0:2025 — Standard Welding Terms and Definitions
AWS A3.0:2025 establishes the following definitions:
Certified Welder: “A welder with credentials attesting to qualification in accordance with an applicable standard.”
Welder Performance Qualification: “The demonstration of an individual's ability to produce an acceptable test coupon in accordance with an applicable qualification standard.”
Welder Certification: “Documentation attesting to the performance qualification of a welder.”
These definitions establish a direct relationship between performance, qualification, and certification. A welder demonstrates the ability to meet an applicable standard through performance qualification. Certification provides documented evidence attesting to that qualification.
The applicable standard may be AWS D1.1, Structural Welding Code—Steel, ASME Section IX, or another governing code or specification.
The distinction is important: qualification demonstrates ability; certification documents that qualification.
The AWS Welding Handbook
The AWS Welding Handbook further explains the employer's responsibility for qualifying welding personnel and documenting their results.
Following successful qualification, the employer prepares a welder performance qualification record documenting the test conditions, applicable essential variables, results, and required certification statement.
The handbook also explains why a welder who has successfully passed a qualification test is commonly referred to as a certified welder rather than simply a qualified welder: the employer certifies the qualification through the appropriate documentation.
This industry practice is consistent with the definitions established in AWS A3.0.
AWS D1.1:2025 — Explicit Recognition of Welder Certification
AWS D1.1 provides particularly direct support for the use of welder certification terminology.
Clause 3, Terms and Definitions, defines:
Welder Certification: “Written certification that a welder has produced welds meeting a prescribed standard of welder performance.”
Welder Performance Qualification: “The demonstration of a welder's ability to produce welds meeting prescribed standards.”
The distinction is consistent with AWS A3.0: performance qualification concerns the welder's demonstrated ability, while certification concerns written verification of the required performance.
Further clarification appears in Clause 6.20, Preparation of Performance Qualification Forms. AWS D1.1:2025 states that the Welding Performance Qualification Record (WPQR) shall serve as the Contractor's certification of qualification and shall list the applicable essential variables identified in Table 6.12. Suggested forms are provided in Annex J.
This provision explicitly identifies the WPQR as the Contractor's certification of qualification.
When these provisions are considered together, the terminology becomes difficult to dispute. The welder demonstrates the required performance, and the WPQR documents the qualification in accordance with the governing requirements.
Is a Welder Qualified, Certified, or Both?
The distinction can be summarized in three parts:
  • Qualification is the demonstration of the ability to produce welds meeting prescribed requirements.
  • Certification is the documented verification attesting to the welder's performance qualification.
  • Certified welder describes an individual whose credentials attest to qualification under an applicable standard.
A welder who successfully completes the required performance qualification has demonstrated the prescribed ability. Once the qualification has been appropriately documented and certified, the individual may be described as a certified welder under the applicable terminology.
Therefore, a certified welder is qualified in the sense established by the applicable definitions. Conversely, a welder who has demonstrated the required performance but whose qualification has not yet been appropriately documented may be qualified without having the corresponding certification record.
The distinction does not mean that certification automatically authorizes a welder to perform every type of welding. The applicable essential variables, ranges of qualification, continuity requirements, and other governing provisions determine whether the qualification is valid for the work being performed.
Certification documents qualification; it does not eliminate the need to verify the qualification's scope and validity.
What Should a Welding Inspector Request?
For welding inspectors, understanding these definitions helps promote precise communication and consistent documentation practices.
When an inspector requests certification records, the objective is to review the documentation attesting to that qualification.
A qualification record must also be evaluated against the applicable code, project specification, employer requirements, and any restrictions affecting its acceptance. An existing WPQR should not automatically be accepted simply because a welder previously passed a test.
The inspector's responsibility is to verify that the documentation establishes qualification for the work in question—not merely that a document exists.
Moving Toward Consistent Industry Terminology
Since my original article on this subject appeared in Welding Inspection Technology in August 2022, I have observed meaningful progress in the industry's understanding of welder qualification and certification.
The explicit definitions published by AWS and the recognition of certification within AWS D1.1 have helped clarify the issue.
I believe applicable codes and industry publications should use welder certification consistently when referring to the documentation that attests to a welder's qualification. Consistency would improve communication among welding inspectors, contractors, quality managers, and welding personnel.
Conclusion: The Welder Is the Subject of the Certification
Welder certification is documented through a WPQR or other record required by the applicable standard. The record identifies the relevant qualification variables and documents the permitted ranges of qualification permitted by the applicable code or standard.
For welding professionals, the objective should be to understand the terminology, comply with the governing code, maintain accurate records, and verify that personnel are appropriately qualified for their assigned work.
The answer is clear: welders demonstrate qualification, and certification documents that qualification. Under the applicable AWS terminology, a welder may properly be described as both qualified and certified when the proper documentation has been properly completed.
References
AWS A3.0:2025, Standard Welding Terms and Definitions; AWS Welding Handbook; AWS D1.1:2025, Structural Welding Code—Steel, Clause 3 and Clause 6.20.
Daryl Peterson is President of Weld Quality Services. He is an AWS Senior Certified Welding Inspector (SCWI), an ASNT Level III, and an API 653 inspector, with nearly four decades of experience in quality-related work.
