Jump to:
The Evolution of Vision-Guided Robotic Welding
For decades, progress in vision-guided robotics has meant better sight. Joint tracking let robots follow a joint. 3D reconstruction let them see the whole part, including warpage and fixturing errors. Today, a welding robot can capture its workpiece in enough detail to plan a program from it.
Yet in most shops, someone must turn what the robot sees into a program: deciding which joints to weld, in what order and with what parameters, then writing the path and motion to match. In high-mix production, that work repeats with every new part, and it depends on a shrinking pool of skilled people. AWS projects that the United States will need more than 320,000 new welding professionals by 2029 (https://weldingworkforcedata.com/).
The bottleneck in welding automation has moved from seeing the part to planning the work. That is the gap AI is starting to close.
How We Got Here
Touch sensing, through-arc joint tracking, and laser joint tracking guide the robot to the actual joint location. Touch sensing locates the joint before the weld, through-arc tracking corrects the path during the weld, and laser sensors can do either. All three remain valuable on linear, repeatable joints. But each senses the joint locally, a point or a cross section at a time, so it can correct an existing program, not create one.
3D reconstruction went further. A complete model of the part as it sits in the cell lets the system plan weld paths and robot motion around reach, singularities, and collisions, simulate the process before production, and absorb variation in part shape and orientation. First-pass quality improves, and variation no longer means starting from scratch.
Both technologies improved how robots perceive their work. Neither removed the programming step. Someone had to tell the robot what the job was and translate it into code.
Planning decides what the robot will do before the arc strikes, which joints to weld, in what order, and with what parameters and motion. Execution adapts as the robot welds to gaps, tacks, and distortion that no preweld scan can fully predict. Joint tracking and arc monitoring have steadily improved execution. Weld programming has not kept pace; offline programming tools exist, but in most shops, programs are taught point by point at the pendant.
How AI Takes on the Programming
AI is now taking on that translation. Instead of writing a program, the operator describes the job in plain language or by marking up the CAD model or scan: weld these joints, stitch these, keep clear of this flange, and so on. AI takes that instruction, along with the part geometry from the CAD model or scan, and generates a program the robot can run.
What makes this more than automated path generation is how the AI handles the task. It works through it step by step, much as an experienced programmer would. It identifies the joints, decides the weld sequence, plans the robot’s motion, and checks reach and collisions. When something doesn't work, it revises the plan itself where it can, and flags what it can’t resolve for the operator. This goal-driven, self-correcting approach is often described as agentic AI; it is what separates the current generation from earlier offline programming tools, which automated individual steps but relied on a person to string them together. Those tools cut programming time sharply.
The second shift is in who holds process knowledge. In most shops, how to approach a particular joint or how to weld a given material and thickness is known to a few experienced people. With AI programming, a shop’s own welding engineers can encode that knowledge as a reusable skill, for example, a multipass fillet on 20-mm structural plate: how many beads, where each goes, the torch angle for each pass, and a weld sequence across the part that keeps distortion in check. The AI applies the skill to every new part with that joint, and engineers refine it as results come in. A shop’s expertise builds up in its own library.
This is also why vision matters more now, not less. AI-generated programs are only as good as the AI’s understanding of the real part, so 3D reconstruction has become the foundation on which AI programming rests.
Shop Floor Meaning
The operator’s role shifts from writing robot code to directing the work and evaluating the results. Welders and welding engineers spend their time on tasks that require their judgment, such as joint design, quality, and process decisions, rather than on line-by-line programming. Shops can also bring that expertise to many more parts. Short runs and one-off jobs that were never worth programming become candidates for automation.
For manufacturers evaluating these systems, a few questions matter more than claims about autonomy, including the following:
How does the system handle the gap between CAD and the real part?
How are process skills captured, adjusted, and reused?
What does the operator’s review step look like before production?
Does it work with existing robots and cells, or does it require new hardware?
What Hasn’t Changed
AI-generated programs do not replace welding expertise. They extend its reach. A plan is only as good as the part it was made for: fitup gaps, tack welds, and fixturing determine results, and thermal distortion on long joints can move a joint after the scan. Weld parameters that depend on the gap still need a welding engineer’s judgment. Reflective materials such as stainless steel and aluminum remain hard to scan, and operators must review generated programs before production. Real-time joint tracking helps correct the weld as it runs; the technology changes where skilled people spend their time, not whether they are needed.
Conclusion
For high-mix manufacturers facing a shrinking skilled workforce and constant changeovers, the advantage is shifting from how well a robot can see a part to how quickly a shop can direct it.
This article was written by Daryl Lim, CEO and cofounder of Augmentus (https://www.augmentus.tech/), for the American Welding Society (https://www.aws.org/).
