Jump to:
Meeting the Challenges of Structural Steel Welding
Structural steel repair welding can be a rewarding and profitable specialty, but success requires more than strong welding skills alone. Welders must understand how environmental conditions, jobsite challenges, and equipment selection affect weld quality, productivity, and profitability. From power availability to access constraints, numerous factors can affect project outcomes, hence the right preparation can make the difference between a successful project and a costly setback. Are you up for the challenge of structural steel welding?
Environmental Conditions
Environmental conditions are often the first consideration when performing structural steel repairs. Much of this work takes place outdoors during building erection, shipbuilding, or equipment repair. Whether ironworking and connecting I-beams, welding fish plates on excavators, or straightening trailer bogie sections, welders must contend with conditions far less controlled than those found in a fabrication shop.
Among these challenges, wind and moisture are two environmental factors that most directly impact weld quality and productivity.
Beating the Breeze
Wind is a familiar concern for most welders. On many jobsites, a repair truck equipped with portable shelters, umbrellas, or welding curtains shields the work area from strong gusts. A weld pool needs shielding, which is why you may notice seemingly strange setups to ensure quality welds are being laid. When wind protection is not practical, welders often switch to processes that provide their own shielding, such as self-shielded flux cored arc welding (FCAW-S) or shielded metal arc welding (SMAW).
SMAW and FCAW-S are still the go-to for structural applications. Their ability to shield the weld pool in high wind environments while still providing deep penetration and robust weld characteristics makes them a staple. The main caveat for these processes is storage. Electrodes should be kept in rod ovens or in sealed packages away from the elements. Precautions prevent whole batches of filler from being scrapped and control an additional variable that can lead to poor quality.
Controlling Moisture
Moisture is the next significant environmental factor affecting weld quality and profitability. Moisture must be controlled in the environment, on the base material, and in the filler material. Beyond obvious concerns such as rain, welders must monitor humidity and dew point levels as well as properly store materials to prevent moisture contamination. While you can hear and see rain, humidity and dew point can silently destroy weld quality while you are none the wiser. Elevated humidity and unfavorable dew point conditions can quietly compromise weld quality by allowing condensation to form on the workpiece, introducing hydrogen into the weld and increasing the risk of porosity and cracking. As every welder knows, water and molten metal are a poor combination. To avoid moisture-related discontinuities, ensure that the materials are dry and comply with Clause 5.15 of AWS D1.1, Structural Welding Code — Steel. When the base metal or ambient temperature is within 15°–20°F of the dew point, consult AWS D1.1 Table 3.2 for guidance. The consequences of inadequate moisture control can be significant. For example, one steel silo manufacturer reported weld rejection rates increasing from 2 to 12% during periods of high humidity (Ref. 1).
Preparing for Jobsite Challenges
Jobsite conditions can significantly affect your ability to weld structural components, as demands can vary widely. Challenges can range from locations more than 200 ft from an outlet to coordinating work around other contractors. Many structural welding projects begin before electrical service is available, making equipment portability and power generation critical considerations. The reach and range of a welding setup can determine where work can be performed and how efficiently it progresses. As a result, equipment selection can significantly influence productivity and project timelines.
One of the most significant advancements in remote structural welding is the introduction of battery-powered SMAW machines. For elevated work and locations where long leads were once required, these lightweight units allow welders to carry the power source directly to the work area, reducing setup time and improving mobility. They also eliminate the need for oversized power sources used to compensate for voltage drop and reduce reliance on forklifts or other equipment for relocation. Many systems weigh less than 50 lb, including leads and accessories, and some can operate while plugged in or through extension cords up to 300 ft long. As battery technology continues to improve, these welding machines are becoming an increasingly practical option for structural fabrication and erection.
Selecting the Right Welding Process
Weld process selection can be either a driver of production or a hard cap. When combined with the right filler metal, the process can significantly improve deposition rates and weld quality and increase overall profitability.
For SMAW applications, some machines offer pulse capabilities that can increase welding speeds by reducing the manipulation and skill needed for vertical welding. SMAW is a robust and proven process but generally very slow compared to other methods.
Modified standard gas metal arc welding (GMAW) waveforms can be used with cored wires to access additional parameter controls, such as wire feed speed regulation that varies with stickout length. These controls can help maintain penetration as stickout changes due to joint access limitations, restricted reach, or operator skill. Some machines even have pulse programs for cored wires to reduce spatter when used with the correct gas (pulsing is generally not possible or stable with less than 80% Ar mixtures). Both are considered high-productivity methods. Combining wire choice with process selection can maximize speeds in certain applications, such as out-of-position welding, because cored wires have a faster-freezing weld pool. For example, even in a shop environment, a cored wire may be a better choice than a solid wire if enough welding speed can be achieved to offset postweld cleaning procedures. Being aware of both filler metal and process options for your application can make you incredibly efficient.
Conclusion
At the end of the day, structural steel welding rewards the welder who plans for the fight before showing up to it. Wind and moisture don’t care about your deadline, so control what you can — block the wind, watch your dew point, and keep your rod ovens and sealed packages doing their job. Jobsite conditions will throw curveballs at you too, whether that’s being 300 ft from the nearest outlet or waiting on a lift. But the right equipment, like a battery-operated welding machine that shrinks your footprint and cuts your setup time, turns those curveballs into home runs. Once you’ve got the environment and logistics handled, process and filler selection are where you hone in. Choosing cored wire over solid or dialing in a pulse program instead of using SMAW can be the difference between slugging through a job and flying through it.
None of these tips are a secret. They’re just easy to overlook when you’re focused on getting weld metal in the joint. Structural steel doesn’t have to wreck your margins. In fact, if you show it the respect it deserves, it won’t feel like you’ve accepted a challenge at all.
Reference
1. Man Xing. “How Weather Conditions Affect Steel Silo Construction Schedules.” Retrieved August 11, 2026, from manxingsilos.com/a/how-weather-conditions-affect-steel-silo-construction-schedules.html.
This article is written by Sean Mckeen (application engineer for Perfect Welding at Fronius USA, Portage, Ind.) for the American Welding Society.
