Jump to:
Guide to Oil Rig Welding Jobs in Texas
Oil Rig Welding Jobs in Texas: Certifications, Pay, and How to Get Started in Houston's Energy Sector
Search for oil rig welding jobs in Texas, and you get a wall of trade school ads, all promising big paychecks and none explaining what the job is. That gap costs people time. A welder who trains for offshore platform work but applies for pipeline jobs, or who shows up without the right test on record, loses months. The fix is knowing which energy job you are aiming for, which code it is built on, and which certification proves you can do it.
This guide breaks down the three career paths that sit under the "oil rig welder" label, what each one pays, and how AWS certifications line up with each. It also covers the requirements outside AWS's lane that offshore employers expect, and how to start your training in Houston.
Why Texas Leads the Country in Energy Sector Welding Jobs
Houston is the hub of the U.S. oil and gas business, and Texas is where much of that business does its welding. Three production areas feed work to Texas employers:
The Permian Basin. The Permian, in West Texas and southeastern New Mexico, averaged 6.6 million barrels per day in 2025 and produced almost half of all U.S. crude oil, according to the U.S. Energy Information Administration.
The Eagle Ford Shale. This South Texas play keeps gathering lines, compressor stations, and processing plants in a steady cycle of construction and repair.
The Gulf of Mexico. Federal offshore waters produced 1.9 million barrels per day in 2025, per the same EIA report. Much of the engineering, fabrication, and crew logistics for that work runs through the Houston area.
All of that production has to be gathered, moved, and processed, which is why energy sector welding jobs are spread across West Texas, the Gulf Coast, and the Houston metro. The Houston metro alone employed 16,660 welders, cutters, solderers, and brazers in May 2023, according to the Bureau of Labor Statistics. That depth makes welding careers in Houston some of the most varied in the country.
"Oil Rig Welder" Usually Means One of Three Jobs
Most people searching for rig welding jobs in Texas picture an offshore platform. In practice, the term gets used for three different careers, each with its own work setting, schedule, and test requirements.
Onshore Pipeline Welders
Pipeline welders, or pipeliners, build and maintain the cross-country, transmission, and gathering lines that move oil and gas from the field to refineries and export terminals. The work is outdoors, often in remote areas, and moves with the project. Pipeliners work with SMAW and GTAW and need to know the welding codes that govern pipelines, including API 1104. A pipeline welder in Texas might spend one season in the Permian and the next on a Gulf Coast lateral.
Offshore Platform and Rig Welders
Offshore welding jobs cover construction, maintenance, and repair on production platforms, drilling rigs, and support vessels in the Gulf. Crews live on the platform during a hitch, and rotational schedules are the norm. Some offshore work happens below the waterline, which falls to underwater welders, commercial divers trained to weld on submerged structures.
Shop-Based Fabrication Welders
Much of the welding behind the energy industry never leaves the shop. Fabrication welders in Houston, Beaumont, and Corpus Christi build pressure vessels, skids, piping spools, and platform modules that are shipped to the field or loaded out to sea. The hours are steadier and travel is limited, and these roles are often the first step into energy work. AWS's welder-fabricator career path covers what the job involves.
| Onshore Pipeline | Offshore Platform | Shop Fabrication | |
| Work setting | Outdoors, remote right-of-way | Platform or rig at sea | Indoor fabrication shop |
| Schedule | Project-based, extended travel | Rotational hitches | Regular shifts |
| Common codes | API 1104 | Varies by owner and structure | Varies by product |
| Extra requirements | Employer and project testing | TWIC, HUET, medical clearance | Employer testing |
What Rig Welding Jobs in Texas Pay
Pay depends on the path, the code you are qualified to, and how far you are willing to travel. As a baseline, the median annual wage for all welders, cutters, solderers, and brazers in the U.S. was $53,750 in May 2025, according to the BLS Occupational Outlook Handbook.
Pipeline work pays above that baseline. AWS's career data, based on Lightcast 2025 figures, puts entry-level pipeliner pay at about $52,000, the national median at $69,000, and top earners at more than $100,000. Overtime and per diem are common on large pipeline projects, and per diem for travel and lodging can add a meaningful amount to take-home pay.
Offshore roles generally carry a premium for rotational schedules, time away from home, and the conditions on a platform. Shop fabrication typically pays less than field or offshore work but offers predictable hours and less travel. None of these figures is a guarantee. Employer, project, union status, and your qualifications all move the number.
The Certifications That Open Doors
Two AWS credentials form the backbone of an energy sector welding career: one for the welder and one for the inspector.
AWS Certified Welder Program
The AWS Certified Welder program is a performance-based test, not a written exam. You weld a test coupon at an AWS Accredited Test Facility, and an AWS Certified Welding Inspector checks the result. There are no prerequisite courses, and the program covers procedures used in structural steel, petroleum pipelines, and chemical refinery work. To keep the certification active, you submit maintenance (continuity) records through WeldCert Pro showing you still use the process. Ask your test facility which procedure or code your test will follow before you schedule.
AWS CWI With the API 1104 Endorsement
For welders who want to move into inspection and QA, the Certified Welding Inspector (CWI) credential is the industry standard. Eligibility combines education and welding experience. For example, a high school diploma plus five years of welding work qualifies. The exam has three parts: Fundamentals, Practical, and an open-book Code exam, and API 1104 is one of the code books candidates can test on.
API 1104 is the American Petroleum Institute's standard for welding pipelines and related facilities. It governs welding on cross-country and gathering-line pipeline construction, so pipeline owners and contractors write it into their specs. Once you hold a CWI, the API 1104 endorsement adds proof that you know it. When people search for "API 1104 certification," this endorsement is usually what an inspection career needs. The exam has 60 multiple-choice questions across five subject areas, including inspection, qualification, and reports and records. Endorsements stay valid as long as your CWI is active, and adding one can also count toward recertification.
Radiographic Interpretation
Many pipeline welds are checked with radiography. The AWS Certified Radiographic Interpreter (CRI) credential qualifies you to read weld radiographs and decide whether indications meet code. It requires 40 hours of formal training and at least a year of radiographic interpretation experience, so it suits inspectors building on a CWI.
The Skills Texas Employers Test For
Pipe welding in Texas is built around a few core skills. Mastering them is what turns a weld test into a job offer.
SMAW and GTAW roots. Root passes on pipe are commonly run with SMAW or GTAW. A clean, fully fused root is the foundation of every joint that follows.
FCAW fill and cap. Flux-cored welding is often used for fill and cap passes on larger pipe because it deposits metal quickly.
6G position welding. In a 6G test, the pipe is fixed at a 45-degree angle, so you weld flat, vertical, and overhead in one joint. AWS recommends practicing 5G and 6G positions for pipeline work.
Blueprint and symbol reading. Pipeliners read drawings, welding symbols, and piping components on the job.
Every pipeline weld also has to pass inspection. Nondestructive examination (NDE) is how QA teams check welds without destroying them. Radiographic testing reveals internal flaws, magnetic particle testing finds surface and near-surface cracks in ferrous metals, and dye penetrant testing shows surface-breaking defects. Welders who understand what NDE looks for make fewer repairs, and inspectors who know these methods are in demand across the energy sector.
Offshore Requirements Outside of AWS
Offshore employers in the Gulf expect more than welding credentials. AWS does not issue the items below, but you should plan for them if offshore work is your goal:
TWIC card. The Transportation Worker Identification Credential, issued by the TSA, is required for workers who need access to secure areas of maritime facilities and vessels.
HUET. Helicopter Underwater Escape Training prepares crews to get out of a helicopter that lands in the water. Training follows industry standards such as those published by OPITO.
Medical clearance. Most operators require a physical before you go offshore.
Exact requirements vary by operator and contractor, so confirm with each employer before you pay for training.
A clear plan matters more than a fast one. Here is a practical path into Houston welding careers in the energy sector:
Pick your path. Decide whether pipeline, offshore, or shop fabrication fits your goals, schedule, and tolerance for travel.
Build pipe skills. Train at a school or apprenticeship that teaches pipe positions, then practice 6G until it is routine.
Earn your AWS Certified Welder credential. Test at an Accredited Test Facility and keep your continuity current.
Get field experience. Hours on real pipe build your skill and count toward CWI eligibility later.
Move into inspection. Earn your CWI, then add the API 1104 endorsement for pipeline QA roles.
Houston is one of AWS's flagship CWI training locations. CWI training in Houston is available in person, through live virtual classes, and self-paced online, with corporate group training for local companies. If Central Texas is closer, CWI training in Austin offers the same certification path, and the full list of CWI training locations shows options across the state and country.
Start Your Energy Sector Welding Career With AWS
Whether you are preparing for your first pipe test or ready to inspect API 1104 work, AWS certifications show Texas employers what you can do. Find CWI training in Houston and plan your next step. Button:
FAQs
Do offshore welders in the Gulf of Mexico need certifications beyond AWS?
Yes, most offshore employers require credentials beyond welding certification. A TWIC card, HUET, and a medical clearance are common requirements for platform work, and some operators add their own safety training. These come from the TSA, training providers, and employers, not AWS. Your AWS certifications still prove your welding or inspection skill.
Is "oil rig welder" the same as a pipeline welder or an offshore welder?
No, "oil rig welder" is a catch-all term for several jobs. It can mean an onshore pipeline welder, an offshore platform or rig welder, or a shop fabrication welder who builds equipment for the energy sector. Each has a different work setting, schedule, and set of test requirements.
What is API 1104 and how does it relate to AWS certifications?
API 1104 is the American Petroleum Institute's standard for welding pipelines and related facilities. AWS offers an API 1104 endorsement for current CWIs and SCWIs, and API 1104 is one of the code books available on the CWI Code exam. Welders are often tested to API 1104 procedures by pipeline employers, and the AWS Certified Welder program covers procedures used in petroleum pipeline work.
How long does it take to qualify for a CWI?
It depends on your education and welding experience. With a high school diploma, you need five years of welding work experience to qualify for the CWI exam. Degrees in welding, engineering, or a physical science can substitute for part of that requirement.
What welding position matters most for pipeline jobs?
The 6G position is the one most pipeline welders train for. The pipe is fixed at a 45-degree angle, so a single test joint covers flat, vertical, and overhead welding. AWS also recommends practicing the 5G position.
