Welding Journal
        Jump to:
Resistance Welding Machines Are Thirsty
        How the right water chiller will improve your machine’s process and save money
        July 2024
    Long known as water hogs, resistance welding machines, including the subcategories of spot, projection, seam, upset, and flash welding machines, generate heat due to the high secondary welding amperages required for the process.
Therefore, an adequate flow of cooling water is one of the process’s most important variables, especially when a resistance welding machine is part ..
Already a member? Log In
Publication Archive
