Complete Welding Lens Shade Chart & Safety Guide for Eye Protection
November 2025
Protecting your eyes is one of the most important safety steps in welding. The intense light, ultraviolet (UV) radiation, and infrared (IR) energy produced by arc welding and cutting processes can cause immediate discomfort, long-term injury, or even permanent vision damage if proper protection isn’t used. Choosing the right lens shade helps you work safely and comfortably without sacrificing visibility or precision. Welding lens shade charts provide quick guidance on what shade number to use for different welding processes and amperage levels.
In this complete welding lens shade safety guide, you’ll learn how lens shade numbers correspond to welding processes, how to interpret a welding lens color chart, and why proper welding eye protection is vital for weld quality, compliance with industry standards, and long-term health.
What Welding Lens Shades Mean
A welding lens shade number indicates how much light the filter lens allows through to your eyes.Shade numbers typically range from 4 to 14, with higher numbers producing darker lenses and greater protection.
  • Lower shade numbers (4–8): Used for non-arc work like oxyfuel cutting, brazing, and grinding
  • Mid-range numbers (9–12): Common for general welding processes such as MIG (GMAW) and TIG (GTAW).
  • Higher shade numbers (13–14): Required for intense arcs and high-amperage welding like stick welding (SMAW) and heavy FCAW.
Understanding welding shade numbers helps you match the lens to your process and welding conditions, so you’re protected without hindering visibility.
Below is a general welding lens shade chart that ties welding processes and arc current to recommended welding helmet shade levels:
Welding Process
Amperage Range (A)
Recommended Shade
Oxy-fuel cutting/torch brazing
N/A
Shade 4–6
Gas Tungsten Arc Welding (GTAW/TIG)
< 50
Shade 8–10
GTAW/TIG
50–150
Shade 10–12
GTAW/TIG
> 150
Shade 12–14
Gas Metal Arc Welding (GMAW/MIG) & FCAW
< 60
Shade 7–10
GMAW/MIG & FCAW
60–160
Shade 10–12
Shielded Metal Arc Welding (SMAW)
60–160
Shade 10–12
SMAW
> 160
Shade 12–14
Plasma Cutting
Varies
Shade 9–14
This welding helmet shade chart gives a strong starting point, but always adjust based on brightness, comfort, and visibility. Auto-darkening helmets often let you fine-tune within a recommended range.
How to Determine the Correct Lens Shade
To select the correct shade:
  1. Identify the welding process you will use.
  2. Check the amperage range you will be welding at.
  3. Start with a shade that feels slightly darker than needed.
  4. Move to a lighter shade (within recommended guidelines) if visibility of the weld pool is compromised.
Using a shade that's too light can allow harmful radiation to reach your eyes, while a shade that’s too dark can reduce visibility and increase mistakes.
OSHA and ANSI safety standards, referenced in ANSI Z87.1 and AWS Standards and Publications, are useful references for minimum protective shade numbers.
Why Welding Eye Protection Matters
Welding arcs generate intense UV, visible, and IR radiation. Without proper protection, this can lead to:
  • UV-induced “arc eye” (photokeratitis)
  • Long-term eye strain and headaches
  • Cataracts or other retinal damage
  • Reduced focus and precision on the weld
Correct lens shades help filter out harmful wavelengths while maintaining clarity of the weld pool. Welding helmets meeting ANSI Z87.1 standards should always be used in conjunction with appropriate lens shade filters.
For comprehensive eye and face safety practices, see AWS resources on welding safety and health.
Choosing Between Welding Lens Shade
Welding lens shade numbers aren’t just about safety — they affect comfort and performance. Lighter shades help you see the weld pool and joint details clearly, while darker shades offer better protection for intense arcs.
  • Shade 8–10: Good for lower-amperage TIG or light MIG work.
  • Shade 10–12: Ideal for general MIG/FCAW and many stick welding conditions.
  • Shade 12–14: Best for high-amperage welding and heavy stick applications.
If you’re unsure which welding lens shade is right for a job, consult the welding lens color chart above and always lean toward safer, darker options when in doubt.
FAQs About Lens Shades
What is the minimum shade for arc welding?
The proper welding lens depends on process and amperage — from Shade 8–10 for lighter TIG work to Shade 12–14 for heavy stick or FCAW.
Is shade 10 or 11 better for welding?
Shade 11 is darker and provides more protection than Shade 10. Choose based on process brightness and amperage. For many MIG and stick applications, Shade 10–12 is standard.
Which welding lens is darker, 10 or 14?
Shade 14 is significantly darker than Shade 10 and offers more protection against intense arc light.
What determines the correct shade of lens for use during welding?
The welding process, arc brightness, and welding amperage determine the correct welding shade number.
How do I determine the correct shade to use when welding?
Match your process and amperage to the shade chart, then adjust based on visibility and comfort.
Why do welders wear blue glasses?
Blue safety glasses are often worn for grinding or lower-intensity tasks — not for arc welding protection. Arc welding requires specific filter lenses with qualified shade numbers.
Which lens shade is best?
The “best” shade is the one that provides adequate protection while still allowing you to see the weld clearly. Use the chart above as a baseline and adjust to fit your process and work environment.
Trust AWS
Strong eye protection is a safety requirement and a productivity advantage. Use the welding lens shade chart above as your baseline, then confirm your helmet settings and PPE choices before every job to reduce eye strain and prevent injuries. To strengthen your safety knowledge and support a compliant welding program, explore AWS Certification & Education. For ongoing technical resources and professional development, consider AWS Membership.
