Jump to:
The Role of Human Judgment in AI-Augmented Welding Inspection
Walk through any modern factory, hospital, or office, and you are sitting, standing, or moving surrounded by welds. Chairs, vehicles, structural beams, pressure vessels, and the electrical systems powering daily life all rely on welds whose integrity depends on inspectors trained to see what most people cannot. Artificial intelligence (AI) is now demonstrating capabilities that, in many controlled conditions, can match or exceed those of even seasoned AWS Certified Welding Inspectors (CWIs). That fact has prompted welding professionals, manufacturers, and the broader industry to ask a question with no simple answer:
As AI matures, what becomes of the human inspector?
This article explores that question by drawing on a presentation delivered at a recent AWS Professional Program session and on broader research into AI adoption across knowledge professions.
The following two goals shape the discussion:
- To describe what AI can and cannot do in welding inspection today.
- To examine the human and organizational factors that determine whether the technology delivers on its promise or quietly fails.
Welding inspection serves as a useful test case because the stakes are high, the technology is progressing rapidly, and the people doing the work have invested years in developing their expertise. The lessons learned here apply far beyond the trade.
The Hidden Cost of Imperfection
The economic case for improvement is well documented. Welding defects, including porosity, cracking, incomplete fusion, and distortion, contribute to the broader automotive warranty challenge that industry analysts estimate exceeds $50 billion annually across all categories of defects (Ref. 1). Add aerospace, pipeline construction, shipbuilding, and infrastructure, and the total quality cost across welded products climbs higher still. Each dollar lost represents not only inefficiency but also a quality risk that can affect public safety.
AI inspection systems address part of that problem. Machine vision platforms now combine high-resolution cameras, acoustic sensors, and thermal imaging to evaluate welds during production rather than only afterward. Industry research indicates that the machine vision welding inspection services market was valued at approximately $1.2 billion in 2024 and is projected to reach $2.5 billion by 2033, a compound annual growth rate of 9.5% (Ref. 2). Vendor demonstrations show inspection speeds of 300 mm/second and defect detection as small as 0.5 mm, compared with a typical 1-mm threshold for human visual inspection. Yet the technology remains imperfect. Surface oxidation, unusual lighting, and material variations can cause AI systems to flag results as uncertain, transferring the burden of judgment back to the inspector.
Three Barriers Technology Alone Can’t Solve
A consistent finding across research on AI adoption is that human factors, not technical capability, decide whether implementations succeed. Three barriers appear repeatedly in welding inspection and across other knowledge fields — Fig. 1.
The first is analysis paralysis. When AI flags a weld as uncertain, an inspector with years of experience must decide whether to accept that classification, override it based on professional judgment, or halt production for additional testing. Each option carries weight in a safety-
critical environment. The result is often more decision points, not fewer, and inspection time can rise rather than fall in the early phases of adoption.
The second barrier is professional identity protection. CWIs complete rigorous AWS training, accumulate years of field experience, and develop what veterans call an eye for perfection. When a sensor and an algorithm match or exceed that ability under controlled conditions, the challenge feels personal rather than procedural. The discomfort is a normal human response, and ignoring it has real consequences for adoption.
The third barrier is competence preservation. CWIs typically invest two to four years in mastering AWS welding codes from D1.1, Structural Welding Code — Steel, through D1.8, Structural Welding Code — Seismic Supplement, along with documentation and visual inspection standards. As AI takes over routine detection, that hard-won knowledge can feel devalued even though the underlying skills remain essential. The U.S. Bureau of Labor Statistics projects that welding employment will grow about 2% from 2023 to 2033, slower than the average across all occupations (Ref. 3). The trajectory points toward fewer purely manual inspectors and greater demand for those who can supervise automated systems.
From Inspector to Intelligent Oversight Specialist
The most useful response to these barriers is to redefine the role rather than defend or replace it. Research from the McKinsey Global Institute estimates that approximately 60% of occupations have at least one-third of their constituent activities that could be automated with currently demonstrated technologies, which calls for substantial workforce transformation rather than wholesale displacement (Ref. 4). The data do not call for fewer welding inspectors so much as a different kind of welding inspector.
In what can be called an intelligent oversight model, the certified inspector validates AI outputs, identifies edge cases, provides context for unusual material conditions, and refines algorithms with field knowledge that no training dataset can fully capture — Fig. 2. The inspector becomes the source of ground truth that the AI relies on to improve. Research by MIT economists Daron Acemoglu and Pascual Restrepo (Ref. 5) finds that for every additional industrial robot per 1000 workers, employment falls by about 0.2% points and wages by approximately 0.42% points in affected regions. Those findings underscore the urgency of preparing the workforce in advance rather than after disruption.
A Human-Centered Future for Welding
AI will not eliminate welding inspection, but it will reshape the work. The inspectors and organizations that lead through this transition are those who treat the technology as a tool that amplifies professional judgment rather than as a replacement for it. Welding has always demanded human attention to detail, ethics, and consequence. That standard should remain the measure by which any new tool, including AI, is judged. When the technology serves the inspector and the public who depend on their work, it earns its place. When it does not, no efficiency gain is worth the risk.
References
- Matrix Automation. 2024. The $50 billion automotive warranty problem: How to reduce costs with smart assembly and digitization. matrixautomation.com.
- Verified Market Reports. 2024. Machine vision welding inspection services market: Size, growth, and forecast 2026 to 2033. verifiedmarketreports.com.
- U.S. Bureau of Labor Statistics. 2024. Welders, cutters, solderers, and brazers. Occupational Outlook Handbook. bls.gov/ooh/production/welders-cutters-solderers-and-brazers.htm.
- McKinsey Global Institute. 2017. A future that works: Automation, employment, and productivity. mckinsey.com/mgi.
- Acemoglu, D., and Pascual, R. 2020. Robots and jobs: Evidence from US labor markets. Journal of Political Economy 128(6): 2188–2244.
KEVIN NOVAK (kevinnovak@2040digital.com) is CEO and chief strategist at 2040 Digital, Bethesda, Md.
