Evaluating AWS Standard Welding Procedure Specifications
Understand the benefits and limitations of these documents
May 2026
By: JAMES SCOTT
In welding and fabrication, maintaining quality, consistency, and compliance is essential, especially when producing critical components for pressure vessels, piping systems, bridges, and structural supports. A tool designed to support these requirements is the AWS standard welding procedure specification (SWPS). As a Certified Welding Inspector (CWI), I still see a great deal of ignorance regarding the proper orchestration of qualifying welding procedures.
SWPSs are prequalified, code-compliant welding procedures published by AWS. They allow fabricators and contractors to perform welding in accordance with recognized standards without having to develop and qualify their own procedures from scratch. While they offer several benefits, they also have limitations.
This article provides an unbiased breakdown of both the advantages of SWPSs and their potential drawbacks to help welding professionals.
Advantages
1. Time and Cost Savings
One of the most cited advantages of using a SWPS is the significant reduction in the time and cost associated with procedure development. Traditional welding procedure specifications (WPSs) must be supported by a procedure qualification record (PQR), which involves material procurement, welding trials, destructive testing, and documentation. This process can cost thousands of dollars and take days or weeks.
A SWPS is a ready-to-use document that can be
implemented completing a demonstration weld (per ASME Boiler and Pressure Vessel Code Section IX). For occasional or short-term work, especially when working with common base materials and processes, this approach can offer efficiency without sacrificing quality or compliance.
2. Code Compliance and Broad Acceptance
SWPSs are written to comply with major welding codes, such as the following:
  • AWS D1.1, Structural Welding Code — Steel
  • AWS D1.2, Structural Welding Code — Aluminum
  • AWS D1.3, Structural Welding Code — Sheet Steel
  • ASME Boiler and Pressure Vessel Code Section IX
  • NAVSEA technical publications
  • National Board Inspection Code
  • American Bureau of Shipping
This ensures the procedures meet code requirements and can be confidently submitted for inspection or customer approval. Some organizations use SWPSs for support of excavation or other temporary structural applications where code clarity on certain materials is limited. In some cases, these prequalified documents help users avoid the need to qualify materials not explicitly listed in code tables, which can be costly and complex.
3. Proven, Validated Procedures
Each SWPS is supported by multiple validated PQRs tested under real-world welding conditions. These records, not provided to the user, ensure the welding process produces sound welds within the specified parameter range. Because these procedures are vetted by committees consisting of experts, they represent standardized best practices for commonly welded base metals and processes, such as shielded metal arc, gas metal arc, flux cored arc, and gas tungsten arc welding.
4. Useful for Training and Entry-Level Fabricators
SWPSs are valuable tools for technical schools, training programs, and small contractors without in-house welding engineers. They provide a solid baseline that can later be adapted or replaced as technical capabilities grow.
Limitations and Considerations
Despite their benefits, SWPSs are not without limitations. These are important to understand to avoid misuse or overreliance, especially in complex or high-risk welding situations.
1. Generic Procedures
An SWPS is designed to be broadly applicable, meaning it may lack specific details welders need for certain applications. Important variables, such as preheat temperature based on material thickness or filler metal selection for specific alloy combinations, may be too general to serve all welding situations effectively.
For example, an SWPS for stainless steel may list acceptable filler metals as ER3XX. However, joining grades such as 321 to 321 stainless may require precise filler metal choices (e.g., ER347), which are not explicitly detailed in the SWPS. In such cases, welders and supervisors must seek clarification, often from sources outside the SWPS.
2. Dependence on User Knowledge
While the SWPS is code compliant, it assumes the user understands welding variables, metallurgy, and code interpretation. Preheat requirements, for instance, may be stated only as “sufficient to prevent cracking,” without specifying values based on thickness or carbon equivalent. If a welder is working on thick-section carbon steel and isn’t provided with preheat charts or supervision, they may lack the information needed to ensure sound welds.
This highlights the importance of training and managerial oversight. In shops where supervisors or engineers don’t have the expertise to interpret or supplement the SWPS, gaps in application can occur, particularly when dealing with postweld heat treatment (PWHT) or notch toughness requirements not addressed in the standard document.
3. Limited Acceptance in Some Codes
Certain codes, such as AWS D1.1, provide exceptions allowing SWPS use, but also emphasize that they may not meet all WPS content requirements outlined in the code. In these cases, approval by the engineer or inspector of record is often required. Additionally, some standards place limitations on which SWPSs can cover base metals and thicknesses, commonly restricting use to carbon and stainless steels between 1/8 and 11/2 in. (See Section 6, “Qualification,” in the 2025 edition of AWS D1.1.)
Furthermore, when used under ASME Boiler and Pressure Vessel Code Section IX, users must complete a demonstration weld to validate that the procedure is being followed properly. This step, while manageable, is sometimes overlooked or misunderstood, which can lead to noncompliance if improperly implemented.
4. Risk of Misuse
One of the primary concerns raised by welding experts is that SWPSs can be misused when management lacks technical knowledge. The issue lies in treating SWPSs as shortcuts rather than tools.
Welders are not typically metallurgists or code experts. An SWPS shouldn’t be the only source of welding guidance.
A real-world example illustrates this risk: a welder joining stainless steel to carbon steel using ER70S-3 filler metal (intended for carbon steel) based on online advice. Had an SWPS been available that clearly specified ER3XX only, it might have triggered a question rather than a misstep. But even then, the SWPS would not have explicitly called out the correct filler metal unless supplemented.
Conclusion
AWS SWPSs are practical, cost-effective options for many organizations, particularly when welding common base metals using manual or semiautomatic processes. They are especially useful for small shops and short-run projects. However, they are not a replacement for technical knowledge, oversight, or training. Organizations must understand their limitations, especially when working with specialty alloys, thick sections, or when notch toughness and PWHT are critical. Supplementing SWPSs with clear shop instructions, preheat charts, and supervision ensures welders have the full context they need to perform their jobs safely and correctly.
SWPSs work best as part of a broader quality management system, one that includes competent leadership, trained welders, and a commitment to doing more than just meeting the letter of the code.
JAMES SCOTT (james.scott@browardschools.com) is the applied welding technologies instructor at McFatter Technical College, Davie, Fla., and an AWS CWI.
