Welding Journal
Jump to:
Wire-DED Industry Update: Standardization and Case Study
This process serves as a viable method for producing large, high-performance metal components
September 2025
Directed energy deposition (DED) is an additive manufacturing (AM) process defined by ASTM as using focused thermal energy sources, such as electric arc, electron beam, and laser, to deposit material at relatively high rates for producing large build volumes. DED can be used to build large metal parts using wire (wire-DED) and gas metal arc welding (GMAW-DED) as the heat source. Depending on the intended use, the deposited material might be heat treated or machined after deposition. GMAW-DED is especially well-suit..
Already a member? Log In
Publication Archive
