Aluminum Q&A
June 2025
By: TONY ANDERSON
Q: Can aluminum be welded with resistance welding processes, such as resistance spot welding? I have used resistance spot welding on steel very successfully; can I use it for aluminum?
A: Resistance welding is defined as follows: a group of welding processes producing coalescence of the faying surfaces with the heat obtained from the resistance of the workpieces to the flow of the welding current in a circuit of which the workpieces form part and by the applicati..
Already a member? Log In
D_Magnifying_Glass_Search.svg
Search Articles
D_PDF.svg
Publication Archive
View past issues of our magazines, including Welding Research Supplements in PDF format.
D_Globe.svg
AWS News
