Welding Journal
Jump to:
Laser-Cut Bevels for Better Welds
Using the right tool early can improve weld fitup, reduce defects, and increase efficiency
February 2026
Always use the right tool for the work. This maxim sticks with me, particularly when I try to take a shortcut. We have all taken shortcuts, and they sometimes lead us operators to have to start over — a sure-fire route to a much longer job. But the right shortcut can save time, which translates to money in a production environment. You just need to think shortcuts through carefully before starting and, of course, make sure you’re using the right tool.
Shortcuts can dramatically improve weld prep, for example...
Already a member? Log In
Publication Archive
