Dialing In GTAW Torch Configuration
Master the core variables that deliver precision and reliability across five commonly welded metals
December 2025
By: GRANT STAHLBERG
Gas tungsten arc welding (GTAW) is widely valued for its precision, arc stability, and clean bead appearance. However, those results only happen when the setup matches the material. No two alloys respond the same after the arc is struck. A configuration that works flawlessly on one metal might lead to erratic starts, poor fusion, or oxidation issues on another. Factors like thermal conductivity, oxide behavior, and alloy reactivity influence arc behavior and weld pool formation.
This article outlines th..
Already a member? Log In
D_Magnifying_Glass_Search.svg
Search Articles
D_PDF.svg
Publication Archive
D_Globe.svg
AWS News
