Facility Accreditation FROM AWS
Jump to:
The AWS QC47 is here!
The Future of Welder Certification is Here!
With enhanced industry alignment and digital integration, it simplifies certification maintenance while reinforcing professional credibility.
Advantages of BECOMING an Accredited Facility
Facilities credentialed through AWS are committed to maintaining the quality and consistency which we are known for worldwide.
Accredited Testing Facilities (ATFs) and CRAW Approved Testing Centers (ATCs) can test and qualify welders from other companies for certification. Certified Welding Fabricators (CWF) have a competitive edge in the international marketplace because their quality management program meets rigorous AWS requirements for welding procedures, welder performance and welding inspection.
Accredited Test Facilities
Put Welders to the Test
Independent laboratories, manufacturing plants, educational institutions, distributors — over 200 industry businesses of all types are currently AWS Accredited Test Facilities (ATFs).
Fill out the application and see if your facility meets the minimum requirements that ensure you can competently and safely administer AWS Welder Certification Testing.
To view a list of Accredited Test Facilities, select one of the links below:
Demonstrate Your Specialized Arc Expertise
If you have the necessary equipment to ensure future welders and repair technicians meet the requirements of the AWS Certified Robotic Arc Welding (CRAW) program, you can boost your company’s status and bottom line by becoming an AWS CRAW Approved Testing Center. With this designation, your company receives industry recognition including an AWS website listing and advertising in Welding Journal magazine.
To view a list of Certified Robotic Arc Welding, select link below:
Mark of Quality Fabrication
The AWS Certified Welding Fabricator (CWF) program is a rigorous best-practices management system that recognizes the craftsmanship of your company’s work. CWF Facility designation instantly signals to potential customers that they can trust the quality of every product.
To view a list of Certified Welding Fabricator Facilities, select the link below:
